Build Advice Pls
Go to solution Solved by TimberWolffe,
I'm well aware that there's better systems, and I'll definitely consider them however I would like to keep the case because I mean look at the thing, it's beautiful. Cheers for the input tho. Popular opinion seems to be leading to an i7 and 16GB RAM. I chose the SSDs and HDD that I did because I saw Linus personally recommending them in other build guides and figured if he likes them then they must be good. Apart from that I'm fairly flexible
So this is my first time designing a build that isn't something giga omega powerful, just something that can run my games and programs on high settings without having to worry about lag. So yeah that's my story, here's the link to my parts list
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=442820&action=wish_lists
Let me know what you think! Super ready to build this if it's going to work, and if it's not I'd love to know what I can do to fix it without blowing 3 grand if possible!
EDIT: I was told PCPartPicker is better for you to help so
http://au.pcpartpicker.com/p/dd9rsY
https://linustechtips.com/topic/373432-build-advice-pls/
So budget is below 3k?
EDIT: Also please use au.pcpartpicker.com so we can help you easier.
https://linustechtips.com/topic/373432-build-advice-pls/#findComment-5051517
Here is my suggestion.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($462.00 @ Centre Com)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($189.00 @ CPL Online)
Memory: G.Skill Value Series 16GB (2 x 8GB) DDR3-1333 Memory  ($146.98 @ Mwave Australia)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($401.99 @ Mwave Australia)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($129.00 @ Mwave Australia)
Case Fan: Cooler Master JetFlo 95.0 CFM 120mm  Fan  ($15.00 @ PCCaseGear)
Case Fan: Corsair SP140 49.5 CFM 140mm  Fans  ($34.00 @ CPL Online)
Monitor: LG 23MP55HQ-P 60Hz 23.0" Monitor  ($175.00 @ CPL Online)
Total: $2410.97
Generated by PCPartPicker 2015-05-26 00:53 AEST+1000
https://linustechtips.com/topic/373432-build-advice-pls/#findComment-5052320
Anyone here? I want to know what changes to make while I'm in the mood
This is much better imo: http://au.pcpartpicker.com/p/TGbKQ7
https://linustechtips.com/topic/373432-build-advice-pls/#findComment-5052366
https://linustechtips.com/topic/373432-build-advice-pls/#findComment-5052518
They aren't bad SSD's but there is no sense in getting 2 small drives for the money the Samsung drives are excellent drives for the everyday user. Same goes for the HDD the quality is there and a better price.
https://linustechtips.com/topic/373432-build-advice-pls/#findComment-5052868
