c# class problem
Go to solution Solved by vorticalbox,
Solved missed a bit of code later on my bad.
        public class court1 : IEquatable<court1>        {            public string time { get; set; }            public string booked { get; set; }            public string client { get; set; }                    }
Giving me the error
Error 1 'BookingXML.Program.court1' does not implement interface member 'System.IEquatable<BookingXML.Program.court1>.Equals(BookingXML.Program.court1)' d:\aaron\documents\visual studio 2013\Projects\BookingXML\BookingXML\Program.cs 12 22 BookingXML
I'm trying to use this https://msdn.microsoft.com/en-us/library/bhkz42b3%28v=vs.110%29.aspx to create a list of bookings.
even the code from the site gives me the same error.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/373364-c-class-problem/
https://linustechtips.com/topic/373364-c-class-problem/#findComment-5050883
Just out of curiosity, but what does this program do?
For college i need to create a system to take bookings for a squash court. I posted before about it and it was suggested to use a DB/text files however i'm getting pushed for time and using a list just seemed like a quicker option.
though i am open to suggestions :)
https://linustechtips.com/topic/373364-c-class-problem/#findComment-5054018
