Modding an S340
Solved by W-L,
i have a gigabyte g1 gaming
Hmm the G1 has a pretty beefy cooler on it, as for modding the front panel like you want above it can be done, I believe that was done by Parvum system if you want ti done by them. They used a new piece of acrylic material after removing most of the front panel.
You can take a dremel using a reinforced cutting disc and doing it yourself. I recommend using masking tape over all the from surfaces and mapping your your design before hand. When cutting be sure to cut away from the line and afterwards using a file to file toward it to get the finished cut to get nice straight lines. Not the mention you will need to touchup the cut edge using some paint to hide the bare metal edge.
