Basically, I have my parts pretty much confirmed, but someone was telling me that my previous case, (the Rosewill Blackhawk), wasn't the best case for $80. Because of this, I was wondering what the best case for $80 actually is for my build...
Build:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($235.99 @ Amazon)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard  ($101.98 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($52.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($349.99 @ Amazon)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($65.99 @ Amazon)
Monitor: Acer G226HQLBbd 60Hz 21.5" Monitor  ($99.99 @ Amazon)
Total: $959.42
So what WOULD be the best case for $80 with this build in mind? Thanks!
https://linustechtips.com/topic/372616-help-with-case/
Super useful, guys! DEFINITELY taking them into consideration! If I have so many options, could I be picky here and ask if there are any blue ones? (LEDs, actual case, doesn't matter haha!)
Thanks!
NZXT S340 with nice blue highlights!
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146197
Graphite 230T with Blue LED fan!
http://www.newegg.com/Product/Product.aspx?Item=9SIA0AJ2CC7344
As for a completely blue case? I don't think so. Not in this price range at least. You might have to look into something like a Phantom from NZXT, but those are closer to $120.
https://linustechtips.com/topic/372616-help-with-case/#findComment-5042687
That graphite is $190 bud
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/372616-help-with-case/#findComment-5042694
Rainbow build!! Haha! But in all seriousness, I could just change the ram, and it would work, right? (Blue, black, white looks decent IMO)
Yes, you would have to change GPU also, that one has red on it
https://linustechtips.com/topic/372616-help-with-case/#findComment-5042773
Look. It's your PC. Make it how you want it. Not how I think, he thinks, or they think it should look! You'll have no compatibility issues with any of these cases, so it's all up to you and your final say-so at this point!
https://linustechtips.com/topic/372616-help-with-case/#findComment-5042774
