Well, you can start of by adding at least one more 970 into that budget.
GPU: RTX 2080 Super        Keyboard: Corsair K70 MK.2 RGB
CPU: i7-9700K        MouseLogitech G PRO Wireless
RAM: 16 GB Corsair Vengance PRO                                                         Headset: Corsair HS70 PRO Wireless
PSU: CX650F        MousepadCorsair MM500 Extended 3XL
MOBO: Asus Prime Z390-A        ControllerDualSense 5
Case: Lian Li Lancool II        CameraCanon EOS M50
Monitor: Samsung Odyssey G5        CoolingCorsair H100i Platinum
The white Rabbit        MicrophoneTrust GXT 252+
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036576
I'm planning to build a 1440p/low 4k gaming PC, but I need to cut the price down as much as possible. ATM i'm at about £1150, but I would prefer it if I could get under £1100.
Any help will be greatly appreciated
My build: http://uk.pcpartpicker.com/p/mJXLLk
Don't know if you can use that CPU / Mobo combo. The 4690K likes a *97 chipset. You can update the bios in some cases, but i'm not sure about this one.
It will play games @ 1440p at medium- high settings. Definetely not ultra.
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036578
will that be a problem?
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036589
That 970 is decent enough for 1440p, I've seen mine struggle with 4K already hence I downgraded to 1440p, other than that you should be fine
If you really want to game in 4K I'd suggest getting a 980 instead, even that won't provide you with the best possible experience, gaming in 4K is pretty expensive
CPU: Intel Core i7 4790K @ 4.8GHZGPU: MSI GeForce GTX 1070 Gaming X (X2 - SLI)RAM: 24GB | Storage: 128GB 960 PRO M.2 SSD, 1TB & 750GB HDD | Operating System: Windows 10, MacOS High Sierra
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036590
How about this?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£179.99 @ Amazon UK)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  (£79.96 @ Scan.co.uk)
Memory: Kingston Fury Red Series 8GB (2 x 4GB) DDR3-1866 Memory  (£47.39 @ CCL Computers)
Storage: Sandisk X110 128GB 2.5" Solid State Drive  (£40.67 @ Scan.co.uk)
Video Card: Asus Radeon R9 290X 4GB Direct CU II Video Card  (£227.15 @ Scan.co.uk)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£57.41 @ Aria PC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (£75.34 @ CCL Computers)
Monitor: Dell U2515H 60Hz 25.0" Monitor  (£239.99 @ Aria PC)
Total: £1085.83
Generated by PCPartPicker 2015-05-23 15:26 BST+0100
Radeon cards tend to do better at higher resolutions.
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036599
1440p gaming = easy
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.97 @ Amazon UK)
Motherboard: MSI Z97I AC Mini ITX LGA1150 Motherboard  (£89.96 @ Scan.co.uk)
Memory: Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600 Memory  (£43.95 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£39.97 @ CCL Computers)
Video Card: XFX Radeon R9 290X 4GB Double Dissipation Video Card  (£229.99 @ Aria PC)
Case: BitFenix Prodigy (Black) Mini ITX Tower Case  (£61.42 @ CCL Computers)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  (£56.03 @ CCL Computers)
Case Fan: Cooler Master Megaflow 110.0 CFM 200mm  Fan  (£9.56 @ Ebuyer)
Total: £1091.84
Generated by PCPartPicker 2015-05-23 15:30 BST+0100
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036625
I would do this build:
PCPartPicker part list: http://uk.pcpartpicker.com/p/Zgyczy
Price breakdown by merchant: http://uk.pcpartpicker.com/p/Zgyczy/by_merchant/
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  (£89.99 @ Novatech)
Video Card: XFX Radeon R9 290X 8GB Double Dissipation Video Card  (£290.00)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£56.99 @ Amazon UK)
Monitor: AOC U2868PQU 60Hz 28.0" Monitor  (£295.56 @ More Computers)
Other: G2A windows (£20.00)
Total: £1139.50
Generated by PCPartPicker 2015-05-23 15:33 BST+0100
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036645
1440p gaming = easy
Total: £1091.84
Is there anything wrong with my motherboard in the original?
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036658
Yes. It's Z87. We're using a Haswell Refresh chip. Unless you have a spare LGA1150 CPU, you'll risk your CPU not working in case of having an old motherboard with an older BIOS.
https://linustechtips.com/topic/372116-need-help-with-my-build/#findComment-5036660
