I'm trying to record gameplay with friends. I was using Teamspeak 3 to record our voices and that picked up my friends and I. That part worked out fine. But, we were playing Tabletop Simulator and when I used my recording software Loilo (I even tried Fraps) to record the gameplay, it recoreded them talking as well. It was only them talking and not me. I didn't have Loilo (or Fraps) set to record voices, I had it set to record only gameplay. My question is if there is a way to fix this. I just want to record gameplay with Loilo (or Fraps) and not pick up them talking.
The only crap solution I found out works is if I take earbuds and have the sound playback set to default device and have my USB Logitech headphones set the sound playback to default communication device. But the problem is that I have to have an earbud in and Have the headset on as well in order for my game recording software to not record their voices. I believe I need it this way so it somehow separates the incoming sounds? I just want to be able to have both the sound of the game and the sound of them talking coming through one headset and record successfully.
I have earbuds, Logitech USB headset and a RazerBlackshark to use. I prefer the earbuds but any will do.
Below are my computer specs
Mother Board: asrock z87 extreme4
Processor Intel® Core i7-4770K CPU @ 3.50GHz
Manufacturer Intel
Speed 3.5 GHz
Number of Cores 8
Video Card NVIDIA GeForce GTX 770
Manufacturer NVIDIA
Chipset GeForce GTX 770
Dedicated Memory 2.1 GB
Total Memory 3.9 GB
Memory 16 GB
Operating System Microsoft Windows 8 Professional Edition (build 9200), 64-bit
Service Pack 0
Size 64 Bit
Edition Professional
Display Maximum Resolution 1920 x 1080
DVD ATAPI DVD A DH16A1L
CD ATAPI DVD A DH16A1L
Drive 1
Size 3.6 TB
Free 1.8 TB
Drive 2
Size 931.5 GB
Free 675.6 GB
Drive 3
Size 232.9 GB
Free 70.2 GB
It may not be explained very well, If more clarification is needed just say so. Thank You!
https://linustechtips.com/topic/371630-sound-problems/
Use a splitter OR their is a setting which you can use a vitual splitter but you would need DXTORY.
Slick:
I don't care if you are right or wrong... someone will come around and correct you if you are wrong. What people need to realize is that we need to step up as a community and get above the pathetic fights and bickering. Share knowledge, be friendly, enjoy your stay.
He also forgot to mention if you dont know about the topic then dont make stuff up. Dont claim fake or assume things just by reading the title, Read the post. It doesnt matter if you made 3,000 as it could be mostly crap...
https://linustechtips.com/topic/371630-sound-problems/#findComment-5031514
"record gameplay" means, its records all of your primary audio output. It can't detect if its from the game or from TeamSpeak.
You have to use two separate audio devices, one for the game (set it to primary audio device) and one for TeamSpeak.
You could accomplish that with 'Voicemeeter'. Just set the virtual audio as primary audio device and loop it to your physical audio. Set the physical Audio device as audio device in TeamSpeak.
~ ThxAndBye
"You should remove any cats from the vicinity, because cats will cause all kinds of problems during CPU installation." -Linus
https://linustechtips.com/topic/371630-sound-problems/#findComment-5031684
