Some fans like the cooler master jetflo 120 include adapter to decrease the speed of the fan which leads to less noise.
this fan contain 3pin or 4pin connector either way you still can control them through the motherboard and lower the speed as much as you want to decrease the noise,
So why does they include those adapters?
The cooler master jetflo case fan 120:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103190
The adapter:
https://linustechtips.com/topic/371409-adapter-for-case-fan/
I think sometimes people want to connect their fans directly to their PSU. Linus did a video where he used these on his home server PC in his living room
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
https://linustechtips.com/topic/371409-adapter-for-case-fan/#findComment-5028246
Yup, having your fans at a set speed means there if no variation in noise. if you want a quite rig you want it quite all the time.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/371409-adapter-for-case-fan/#findComment-5028251
Depends much on mobo if it has ability to lower speeds or do any kind of control. LNAs are easy way to make otherwise good fans more quiet, even with older mobos.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/371409-adapter-for-case-fan/#findComment-5029279
