Custom Build not Posting with CPU
Unfortunately, the stock bios on H81m doesn't support haswell refresh, which is what the G3258 is. As the poster above me said, msi requires version 1.4 or greater, but I have heard of some people still having trouble with 1.4, and needing 1.5 to fix the compatibility issue. The problem is you'll need a working cpu to update the bios, such as an original haswell cpu. You'll need it to at least post so you can use m-flash. Or you can take it to a local store, but they'll probably charge you $30-$50 to do it. You can buy an old celeron like the G1820 on amazon for $40 to flash the bios and then sell it again on ebay to get your money back. Just make sure not to get a haswell-refresh like a g1840, or you'll be in the same boat.
I know neither of those options are great, since this is a budget build.
On the brighter side, i believe the newest bios allows you to overclock with that board. Not positive though. Best of luck.
p.s. make sure to follow your topic on the top right of the page to make sure you see replies.
