My Planned Build - Safe Temps?
Go to solution Solved by cheeze_tartz,
Your temps will be fine. If your PC gets too hot it will shut down to protect itself, or your components will thermal throttle.
Hi, this is my rig that I'm planning on building and I need to know safe temperature or where I can find them please - this being said, if temps start going out of control, is there a way to turn off the computer or does this come automatically on some or?...
Case - CaseLabs - Merlin SM8
Motherboard - ASUS P9D WS
Processor - intel core i7 4790K
CPU Cooler - Stock or some kind of Noctua
Graphics card - Nvidia Titan X
Power Supply - Seasonic 1050W snow silent
RAM - Corsair Dominator Platinums
https://linustechtips.com/topic/371285-my-planned-build-safe-temps/
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
this makes very little sense.  the system if assembled properly with stock cooler should run around 70C and with the some kind of Noctua it will be less theoretically because some kind is not a model. and yes your cpu will not run if the temps exceed the max temp threshold
I haven't decided which kind of noctua cooler yet, that's why it says some kind
What kind of programs do you recommend to check temps?
Coretemp
