Try this: http://amzn.to/1FqMUjN
I have no idea how good this will be. Flat cables are not very common and tend to be sold be quite 'dodgy' companies
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
https://linustechtips.com/topic/371064-10m-ethernet-cable/#findComment-5023735
I have a 15m one of those and they are really nice to tuck under your carpets or to manage in general compared to standard cylindrical ones. Can't go wrong with them OP :) They are dirt cheap too.
https://linustechtips.com/topic/371064-10m-ethernet-cable/#findComment-5023752
