Hi, I am about to start on a new build and I was just wondering what case to buy. I got some suggestions and so far the Enthoo pro and the fractal define s are looking good. I am planing to watercool my new rig and, from a watercooling perspective, the define s looks better (because of the larger rad support) anyway, I was just wondering what case you would suggest: the define s or the Enthoo pro, OR something entirely different.
My build plan: http://au.pcpartpicker.com/p/cs7crH
Note, I am going for a blue build (blue ram, blue ssd, blue mobo, ect)
The case would need a fan controller and I would like it to be black and with a side window. Also cable management is important to me. Thx
https://linustechtips.com/topic/370808-enthoo-pro-vs-define-s/
Define S.
https://linustechtips.com/topic/370808-enthoo-pro-vs-define-s/#findComment-5020505
Why? (Sorry if I sound like a two year old!)
It's got sound dampening foam all over inside, so it will be a bit quieter, and also has a shitload of different options for watercooling, and no drive bays or anything that would get in the way.
https://linustechtips.com/topic/370808-enthoo-pro-vs-define-s/#findComment-5020560
The cases don't even compete with each other.
The Enthoo Pro is a classic case done right at an affordable price point. You'll get plenty of support for HDDs and 3 optical drive bays, along with handy stuff like Velcros for cable management.
The Define S is pretty much a watercooling case, though most people will probably throw an AIO there and enjoy all the empty space and unrestricted-ish airflow. It accepts only a couple of hard drives and has no 5.25 external bays. If you want to know about alternatives, I guess H440 and the Phantom variation for noscope MLG players are the closest bet.
https://linustechtips.com/topic/370808-enthoo-pro-vs-define-s/#findComment-5021095
You have a CD burner in your part list, the Define S has no 5.25 bays.
/thread
CPU  5820k - 4.0GHz @ 1.27V  |  MOBO X99-Pro  |  RAM 16GB Ballistic @ 2133MHz  |  PSU HX750i
 COOLING  Kraken X61 - 6x NF-A14 iPPC  |  DRIVES  256GB 950 Pro - 2x 1TB Travelstar - 1x 1TB WD Black
GPU  EVGA GTX980 SC |  CASE  R5  |  OS  Win 8.1 Pro  |  MISC   Cablemod C-Series White Set
https://linustechtips.com/topic/370808-enthoo-pro-vs-define-s/#findComment-5022642
