Just got a smurf and I'm looking for low ranked players so I don't get ranked with Nova Masters/MG so if you want to play with a smurf get leveled up maybe just add me!
http://steamcommunity.com/id/Caleb_Smurf/  I will be on later tonight. I wont be able to use my mic on weekdays, I do callouts though.
I am currently unranked on my smurf.
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/370441-cs-go-low-silvers/
Don't be a bitch,play against people your own rank and stop ruining it for the silvers.
https://linustechtips.com/topic/370441-cs-go-low-silvers/#findComment-5016048
Well it's not just that, I'm trying to get a higher rank, my main isn't the rank it should be, it's Nova 1 but I can destroy Nova Masters. I just want to ensure that I get the rank I want.
Current PC:
https://linustechtips.com/topic/370441-cs-go-low-silvers/#findComment-5016758
i never played competitive before, what is it like
Not sure how to explain it. Want to play?
Current PC:
https://linustechtips.com/topic/370441-cs-go-low-silvers/#findComment-5016793
You won't get a higher rank playing with silvers. Man up and play a higher rank and don't ruin it for others.
https://linustechtips.com/topic/370441-cs-go-low-silvers/#findComment-5040431
