Will it work?
Go to solution Solved by vorticalbox,
Hello all, yesterday I asked for some pc parts available in my country and they listed me this:
b85m e45
i3 4160
My question is if the mobo will support the 4160?
Also I have a Strix GTX750ti, 650W psu, 8gb ram 1333 hyperX (without use), this will be replacing a q8400 w/ 4gb ram 800
took me less than a minute to find this.
http://uk.msi.com/support/mb/B85ME45.html#support-cpu
yes it will work.
b85m e45
i3 4160
CPU i3 4160 MoBo B85M E45 GPU ASUS GTX750TI OC 2GB
RAM HYPERX 8GB 1866 PSU Enermax 650w CASE TT H23 WINDOW
https://linustechtips.com/topic/370363-will-it-work/
b85m e45
i3 4160
yes it will work.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/370363-will-it-work/#findComment-5015033
yes it will work.
Thank you dude, sometimes mobile browsing give me headache
https://linustechtips.com/topic/370363-will-it-work/#findComment-5015091
