So i would like to buy a TV i don't want a 4k one its still expensive
I would like a 121 cm (47") SmartTV i don't want it to have 3D, i would not use it (my head hurts from it)
It doesn't need to have WiFi , the router will be just under it.
The budget is 550 euros, location Europe (Romania)
It will be used mainly to stream movies from my pc from the other room to the living room where the TV will be placed
https://linustechtips.com/topic/370116-help-me-find-a-tv/
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/370116-help-me-find-a-tv/#findComment-5011462
