So I just assemble my first PC.
When I start my PC the screen says "Please reboot and select proper boot device."
I tried putting my Flash Drive which has the OS but it can't detect the hard drives.
I can't seem to find the bios and I think my bios is outdated? I'm using Intel Pentium G3258 and Gigabyte GA-B85M DS3H.
Also using NZXT H440 so I dont have room to put the disk
(sorry first time in this kind of things)
https://linustechtips.com/topic/370087-what-should-i-do-first/
Do you have a external USB optical drive? Try that maybe?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/370087-what-should-i-do-first/#findComment-5010828
Go to the BIOS and select your boot device to the USB. If you don't know how to get to the BIOS, turn on your PC and press the Delete key rapidly.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/370087-what-should-i-do-first/#findComment-5010829
No need for that, you just need to set the boot priority to the USB stick.
https://linustechtips.com/topic/370087-what-should-i-do-first/#findComment-5010832
Thanks for the answer but I have a new problem and i'm going in circles
I'm installing windows 8.1 which my friend gave me but I got problem like.
Compatibility report.
The computer started using the windows installation media. Remove the installation media and restart your computer so that windows starts normally.
https://linustechtips.com/topic/370087-what-should-i-do-first/#findComment-5010892
Sounds like you are trying to install an upgrade version. Upgrade versions can only be installed from within existing Windows.
https://linustechtips.com/topic/370087-what-should-i-do-first/#findComment-5010906
https://linustechtips.com/topic/370087-what-should-i-do-first/#findComment-5010913
