1st off welcome.
Second post this in new builds and planning the sub forum next time ;3
3rd if you go on part picker and add the NZXT Noctis N450, it will do a compatability check and tell you
EDIT: if you are new to pc building do not water cool as you can cause serious dmg to the system if you dont do it right
My article on subscription based services and why they are the way forward http://linustechtips.com/main/topic/382625-what-the-future-holds/
