I didn't know where to put this, so it's going here
I need to illuminate my backyard with some high power lights for night golf and parties and stuff
My backyard is 32ft x 56ft
I can put the light on the side of the house
Does anybody know where to buy flood lights and which ones would be good?
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/368855-need-flood-lights/
Not exactly sure if this is what you're after, but through our electric company, we had a light fixture installed, because we're in the country, so when it's dark, it's really dark. We paid for the installation, and pay $7 a month for it. It illuminates about 4 acres of our property, and costs us $7 a month. It only turns on from dusk to dawn.
Maybe try going through your electric company to see if they can install a light(s) for you? Unless you really want to buy your own. Then, I have no clue.
https://linustechtips.com/topic/368855-need-flood-lights/#findComment-4993921
4 acres? damn
My backyard is only 1800 square feet, so I think just 1 or 2 smaller lights would work
https://linustechtips.com/topic/368855-need-flood-lights/#findComment-4993930
Not sure about supplies where you are, but i not long ago got an LED SMD flood light for my drive, only 20Watts but very powerful!
See if you can get a SMD LED one, you will probably want a more powerful one, so look at 40Watts maybe.
just my 2cents!
|CPU| i7 4770K @ 4.4GHz |Motherboard| Asus Z87 MAXIMUS VI HERO |RAM| Corsair Vengeance 16GB 1866MHz |GPU| EVGA GeForce GTX 770 2GB
|HD| 256GB SSD 850 PRO |Sound| Creative Sound Blaster Z High Performance |Case| NZXT Phantom 410 |OS| Windows 10 x64
https://linustechtips.com/topic/368855-need-flood-lights/#findComment-4994763
-An old CPU heatsink
-An old PC PSU
-Boostconverter 150W+ from eBay ~10$
-100W led from eBay ~5$
-Some wires, thermal grease, drill, screws nuts, soldering iron and a DMM.
Attach the led to the cooler and run it at ~70w
https://linustechtips.com/topic/368855-need-flood-lights/#findComment-5000014
