I've been wanting to build a computer for a while now since I broke my laptop. I plan to add a graphics card later due to my budget. I want to know if this is a good build that is somewhat "future proof" and will deliver good performance for what I'm spending.
http://pcpartpicker.com/p/ZG9gxr
https://linustechtips.com/topic/368769-my-first-pc-build/
What's the system being used for? No ssd?
Is the optical drive really necessary?
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4992509
Go for a Cryorig H5 or be quiet! Shadow Rock 2 for the cooler and get a slightly better motherboard. Add in something like a 290X or a GTX 970 down the line and you will be ready to go with a good gaming rig. Do you really need the ODD or fan though?
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4992514
Go WD Blue, save some money, and also an SSD is pretty much godsend! If your budget allows it!
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4992539
I will need the optical drive for burning CDs, as my truck doesn't have AUX. As for the fan, do you think that this system will get enough airflow with just the stock case fans?
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4992609
The system will be used for gaming and running CAD programs from time to time. Should I spend the extra money to get an ssd? And yes, I will need an optical drive.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($113.99 @ SuperBiiz)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($56.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case  ($57.99 @ Micro Center)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer  ($13.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.88 @ NCIX US)
Total: $680.81
Generated by PCPartPicker 2015-05-17 23:42 EDT-0400
I slashed 95$ bucks off and got a better motherboard that can run sli if you take that route down the road, get a ssd first its way easier to add a Hard drive latter then adding a ssd later, also you can use a stock cooler until you get the more cash, and I also put in a better power supply. Personally I would put the extra 95$ towards a better case but the choice is yours to do with it as you wish.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4992728
Total: $680.81
Thanks for the helpful advice. I will definitely go with the ssd first, as I won't be downloading anything huge until my rig is ready for gaming. As for cooling, I won't be overclocking until gaming, so the stock fan only makes sense as of right now. What case would you recommend?
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4992857
My case suggestions are anything over the 60-80$ made by Fractal Design, NZXT, or Corsair that is compatible with your components.
But if you would be willing to spend a little extra I would forgo the case for now and run the thing on your desk and buy this thing while it's on sale because it's dirt cheap.
https://pcpartpicker.com/part/sapphire-video-card-1003612sr
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993010
Getting a ssd makes a world of difference and I'd highly recommend getting one.
Gaming yet no graphics card?
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993421
I am going to buy a graphics card later when I get more money. I'm just trying to get the bare necessities for right now so I can get this computer ordered up and built ASAP.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993559
You could just get the graphics card from the get-go: http://pcpartpicker.com/p/6KqjQ7
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993622
Yes that works but it is sacrificing so much performance, if he wants to build it progressively and is willing to wait why would he need everything now but with so many compromises.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993666
Where's the 'so much performance' and 'so many compromises' you're mentioning?
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993674
No overclocking, no possibility for crossfire let alone sli, worse SSD, worse graphics card, no dual channel RAM, worse power supply, worse stock clock speed.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993714
The difference between the 4440 and an oc'ed 4690k isn't much for most games. The SP600 isn't far behind other decent SSDs and the difference is likely unnoticeable. A graphics card is better than no graphics card. The difference between single and dual channel ram for gaming with a dedicated graphics card is negligible. The psu doesn't have any practical difference as long as it works.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993757
There is still a difference when going with 4690K in things like games that do use it and other tasks that benefit from faster cores.
The SP600 has good reads but crap writes.
He said he was going to buy a graphics card down the road a bit because he's OK with waiting.
There is still a difference when using single channel some tasks are worse with it.
The PSU matters the most because what happens if it stops working, oh yea it can take most of your system with it.
Yet you still never mentioned the fact that the board you choose had only a single PCIe slot that runs at 2.0 16x witch makes it even more of a joke.
And everything you said basically aquaints to this: it won't effect gaming the difference will be negligible. Open your eyes there is still a difference and you can use computers to do more than just game.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4993840
For everyday usage, write speeds don't make that much of a difference for a drive that is just going to store the OS and programs. It's still faster than the Fury you recommended: http://ssd.userbenchmark.com/Compare/Kingston-HyperX-Fury-120GB-vs-Adata-SP600-128GB/2586vsm7306
Please link a practical scenario where the difference between single and dual channel would be applicable.
The 500B1 isn't bad. It shouldn't take out the system if it dies like any other decent psu.
The difference between 2.0 and 3.0 16x is negligible for today's cards in gaming.
There are differences but they are negligible--please mention what would actually take a perceivable hit since you make it seem so drastic as to call it 'so much performance' and 'so many compromises' but don't give actual examples other than 'other things'. Link benchmarks showing how much or how little those things actually matter.
So far, the compromise comes down to lack of oc'ing which really isn't worth the money for those who don't need the power and isn't that much of a difference until games become more cpu heavy in a few years or so and lack of sli/cf which usually isn't recommended when the time comes to upgrade and is an upgrade most people don't go with despite having planned to in the past.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4997505
Your so fricking stubborn, the op said he was going to be getting stuff later on why the duck do you think he needs or all now.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4997522
I never said anything about needing it now. I'm just showing a similar performing system for a few hundred dollars less. After all, why spend more if it's unnecessary or not very helpful?
You're actually the one saying the difference is all so big yet don't actually show benchmarks or tests--basically exaggerating on the behalf of the worse recommendation.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4997567
But dat fps doe.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4997578
But dat fps doe.
Exactly--what fps?
Link some benchmarks instead of saying 'the difference is massive but I won't show you'.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4997596
Exactly--what fps?
Well if you have a better CPU and better GPU why would you need benchmarks it's common sense.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4997631
Because you say the difference is huge when they are not.
It's like how the 7970 is better than the 7950 but isn't massively better or worth several hundred dollars more.
https://linustechtips.com/topic/368769-my-first-pc-build/#findComment-4997639
