Hello I was wondering about the noise levels of the define s due to teh fact that im goign to live ina college dorm in august and really dont want to bug my room mate. im panning to rebuild my whole system for queiter operation this summer and if any other parts that you have used for thsi purose would be greatly taken in to concideration.
https://linustechtips.com/topic/368478-silent-case-questions/
I heard they are pretty quiet, so you're fine. Unless you put a ton of fans in at high RPM.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/368478-silent-case-questions/#findComment-4988145
A quiet case helps but a quiet case can't do magic you will need silent hardware aswell.
But the Define s is a whole bit less silent when compared to a R4/R5 since it's a cheaper case and is lacking some sound dampening features.
https://linustechtips.com/topic/368478-silent-case-questions/#findComment-4988148
It's going to be the pc components that are the most contributing factor, quiet low rpm fans, psu and gpu fans that  only spin up when necessary heck you will probably annoy your room mate with your key strokes.
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
https://linustechtips.com/topic/368478-silent-case-questions/#findComment-4988252
