individually sleeved cables
By
Dantastico
in Cases and Mods
in Cases and Mods
Solved by matthewmarchant,
There are tons of custom cable websites but I use bitfenix alchemy. (I don't recommend the nzxt sleeved cables) You will probobly need: 1x 20+4 pin/24pin, 1x 8pin/4+4pin mobo power, 1-2x 8pin or 6pin gpu connectors. and you can get sata power, or sata cables aswell if you want them but I dont think it's necessary
toxic_worper ·
Posted in New Builds and Planning8 -
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
