I have two GTX 260's which for a while worked fine and upped performance gains by quite a bit and just randomly my second GPU spiked to 100 degrees and froze my system, this has happened like 3-4 times over the past week so I decided to take it out, I'm not sure what is causing it to be fine one moment and then spike the next, somedays I would play a game for 3-4 hours fine then the next 20 minutes on and it would do that. I thought it was my CPU causing the issue until I caught afterburner showing it at 99 and I know most any card shuts it self off or basically freezes at 100. I guess It might be dying but I dont know, im going to try applying new thermal paste but i mean when it runs fine, it runs at like 50-60 so kind of doubt its that. anyone else haver any ideas?
Alright so i took it apart and it has tons of the cloth thermal pads that are just like super messedup, would it be ok to remove thoe and just put thermal paste their instead?
https://linustechtips.com/topic/3679-sli-260-issue/
  • 4 years later...
it may be a bad sensor
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/3679-sli-260-issue/#findComment-9928972
