I know serial is really old but I have some hardware that I need to configure via serial. I have a Dell Dimension L733r with a serial port and a 3COM Superstack II switch. Below is pictures of what I have so far. With the serial cable I have, do I need a gender changer or a new cable. I would need Amazon links. Thanks!
IMG 9853
Serial Cable
https://linustechtips.com/topic/367065-serial-cable/
What you have there is a serial extension. You can either buy a new cable (http://www.amazon.com/Tripp-Lite-Modem-Serial-P450-006/dp/B000067SCH/ref=sr_1_6?ie=UTF8&qid=1431700317&sr=8-6&keywords=serial+cable) or a gender changer (http://www.amazon.com/StarTech-com-Slimline-Serial-Gender-Changer/dp/B00066HOXY/ref=sr_1_1?ie=UTF8&qid=1431700339&sr=8-1&keywords=serial+cable+gender+changer). The gender changer actually costs more than the new cable.
EDIT: According to the switch's manual, you will need a Null modem cable. If you want to keep using your extension, then you will need a null modem adapter (like this http://www.amazon.com/StarTech-RS232-Serial-Modem-Adapter/dp/B000DZH4V0/ref=sr_1_1?ie=UTF8&qid=1431701711&sr=8-1&keywords=rs232+null+modem)
Molex to SATA, lose all your data
https://linustechtips.com/topic/367065-serial-cable/#findComment-4970846
there are USB to RS232 converters that you can buy.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/367065-serial-cable/#findComment-4970917
So I can use my black cable with this: http://www.amazon.com/StarTech-RS232-Serial-Modem-Adapter/dp/B000DZH4V0/ref=sr_1_1?ie=UTF8&qid=1431701711&sr=8-1&keywords=rs232+null+modem
https://linustechtips.com/topic/367065-serial-cable/#findComment-4971397
