Here's to hoping this is in the correct place...
Anyway, I recently bought a Raspberry Pi 2. This means I can retire my old model B and use it for a project I've been wanting to do for some time. I want to use my Raspberry Pi as a remote for my PC.
I can't justify having my PC on 24/7 but I can justify having a Pi on like that, so I'm planning to hook the Pi up to send a pulse on the GPIO pins to start the motherboard. I'm keeping the switch working as is. I plan on using a optocoupler, I'm looking at a diode based opto-isolator for switching speed and low current transfer (Really don't want to mess around with the current on the motherboard...).
Since my Pi is going to be inside my case, I'd like to power it off the PSU so I need a internal USB to USB connecter first (needing to check USB2.0 current). I also need my Pi to have internet which might be a problem until I can route fibre to my room and run wired.
So, are there any suggestions as to ways you think I could improve this or any feedback on extra things I should have my Pi do (Other than control the LEDs I want to buy)?
https://linustechtips.com/topic/366959-raspberry-pi-remote/
@Casperian You could just use Wake-On-LAN? (If you have an Ethernet cable into your PC that is). Wake On LAN: http://www.howtogeek.com/70374/how-to-geek-explains-what-is-wake-on-lan-and-how-do-i-enable-it/
But I guess doing that project would be cool anyway
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/366959-raspberry-pi-remote/#findComment-4969512
Sadly, I'm running wireless.
Also the Pi way can shutdown the PC too, or force it off if necessary.
https://linustechtips.com/topic/366959-raspberry-pi-remote/#findComment-4969551
Ahh right, well goodluck with whatever you do  :lol:
https://linustechtips.com/topic/366959-raspberry-pi-remote/#findComment-4969559
