Hey Everyone.
This will be my first build and I am just wondering if I'm making any mistakes and also looking for advice. I am looking to spend around £675. I will be getting dual 960s much later on. I have dual monitors already and peripherals (mouse, keyboard, speakers). I will be running windows 8 and upgrading to windows 10 when it comes out. It will be for gaming, video and photo editing and general use. I will be doing some overclocking. Also what are peoples opinions on newegg? Should i buy from there as it's cheaper or does it have major flaws? Also should I be spending more on the psu or is that one okay? And are there better cases for around or under that price.
Thanks in advance.
http://uk.pcpartpicker.com/p/HQy2Lk
https://linustechtips.com/topic/366501-first-build/
I had a good experience...
Have you ever wondered why the codes are so cheap? The codes aren't supposed to be sold by G2A, but are actually meant for students. If you have to reinstall windows you're fucked. Because the code is one use only
"I fart in your general direction" -The Frenchmen
https://linustechtips.com/topic/366501-first-build/#findComment-4964036
