Ethernet Crossover cable
Go to solution Solved by TheKDub,
Yes, but there isn't really a reason to get a crossover cable for it as it supports auto-midx, which means it can sense if it needs to swap outputs and such, so can use it in that situation.
(Basically it uses the normal ethernet cable like a crossover cable by changing what pins are for what, but can also still be used as any other ethernet card would.)
http://www.intel.com/content/www/us/en/network-adapters/gigabit-network-adapters/gigabit-ct-desktop-adapter.html
If I buy 2 of these cards and a crossover cable, could I transfer data between 2 desktops?
I have a lian li dk02 and I want my pcs to be more in sync with each other
will the transfer speeds be any good? both pcs have ssds in raid
https://linustechtips.com/topic/366187-ethernet-crossover-cable/
https://linustechtips.com/topic/366187-ethernet-crossover-cable/#findComment-4960096
so I could use a standard ethernet cable and it will all work fine?
https://linustechtips.com/topic/366187-ethernet-crossover-cable/#findComment-4960164
Yep.
https://linustechtips.com/topic/366187-ethernet-crossover-cable/#findComment-4960288
