When I stream with obs, my microphone sounds great but my desktop audio sounds really distant and echoey sort of. I have tried all sorts of options within obs and windows but nothing I try seems to fix the issue. If you are wondering what the audio sounds like,http://www.twitch.tv/imelkay/profile/past_broadcasts here is a link to my past broadcasts. Anyone of them should have me playing spotify or tallking to someone on teamspeak.
https://linustechtips.com/topic/366070-obs-streaming-problems/
I'm going to straight up assume you have realtek audio drivers.
usually you have a thing an in-built thing called stereo mix which records your desktop sound, I'm not sure but is there not an option to set a second microphone?
Also your previous streams aren't loading properly for me
For this I'm going to ask, do you have the stream open while you're playing?
If not then I'm going to assume it's OBS playing it back which is causing the echo.
And for the distant part it's probably the setting of the desktop volume.
https://linustechtips.com/topic/366070-obs-streaming-problems/#findComment-4958612
yes I do have realtek drivers.  No I don't have the stream open.  I do believe it is an OBS playback issue.  My windows volume was at 100, so should I drop it and see if that works?
https://linustechtips.com/topic/366070-obs-streaming-problems/#findComment-4958799
