why would you not get a single 970 instead??? or 290x
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
https://linustechtips.com/topic/365619-will-this-build-work/#findComment-4952467
Two cards look cool, that would be my only argument.
much more heat noise and power consumption though...
https://linustechtips.com/topic/365619-will-this-build-work/#findComment-4952499
dont quot me on this but i think crossfire is only on amd boards (i think)
this is not true
also i quoted you :o
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/365619-will-this-build-work/#findComment-4952508
Yolo you know, I own two cards because I wasn't planning on adding another one but did and I love the look of it.
Yes power is higher, heat wasn't really an issue and with the latest silent modes these cards have, the noise isn't bad. Personally I like two cards and will always have two just because the coolness of them. BUT at being said, I would go for 1 Nvidia card over 2 AMD cards.
blackshades on
https://linustechtips.com/topic/365619-will-this-build-work/#findComment-4952527
