CPUFAN is controller by CPU temps
SYSFAN is controlled by general system temps :)
Plug any CPU Cooler fans in to CPUFAN and case fans in to SYSFAN
https://linustechtips.com/topic/365178-cpu-and-sys-fan/#findComment-4946575
So I plug the msi cooler into cpufan?
http://www.scan.co.uk/products/msi-dragon-oe3-v298001-all-in-one-watercooler-for-all-intel-and-amd-cpus-with-120mm-radiator-s115x-2
And the Corsair AF120 into the sysfan correct?
Can I ask how do hardware fan controllers work then?.
https://linustechtips.com/topic/365178-cpu-and-sys-fan/#findComment-4946644
The AF120 will go in to SYSFAN while the 3 pin cable coming from the pump I would recommend putting it in SYSFAN as well since pumps need constant speeds not variable.
The fan on the actually water cooler itself will be CPUFAN though
https://linustechtips.com/topic/365178-cpu-and-sys-fan/#findComment-4946655
Oh snap so there's two leads for the msi cooler, is that normal?.
https://linustechtips.com/topic/365178-cpu-and-sys-fan/#findComment-4946664
Yes, one for voltage to the pump one for voltage to the fan.
https://linustechtips.com/topic/365178-cpu-and-sys-fan/#findComment-4946692
