Modded cables or not?
Just wandering why sleaved cables are so expensive, had a look at cablemods and it was like $130AUD for a black and white kit which is like $20 less then my case?
Like WTF I understand they look nice but I'm not paying that, I was thinking instead of that getting only custom black GPU cables (which I have no idea where to get) and black sata cables for my drives, so it has the same effect (You'll understand once you look at my build on my steam here:)
http://steamcommunity.com/sharedfiles/filedetails/?id=422232652
So yeah basically the Sata cables are the most ugly thing i've ever seen and need to go now, but what about the GPU cable? Will it even look bad once I get rid of those horrid sata cables? Where and what should I get instead of the sleeved yellow ones?
(Black sata cables http://www.mwave.com.au/product/50cm-core5-premium-sata-iii-cable-black-ab49187)
Basically just want my build black and white, (define r5, and z97 krait)
Without spending that much (Please no more than $60)
https://linustechtips.com/topic/365148-modded-cables-or-not/
What ones do I need though, so many different ones but my build might not need them all
They are sold separately for each cable, just pick the ones you need, for example you NEED - 24pin motherboard, 8pin motherboard, 6+8pin GPU (depending on GPU), and MAYBE SATA :) And for color, pick the one you want
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4946239
We can sleeve both SATA data and the GPU cable for you. You can check out our prices here:
https://modguru.net/product-category/exten/
And our gallery here:
https://modguru.net/gallery/
Contact us for a quotation or a chat [Modguru shop] [Facebook] Creating the highest quality products ever
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4947233
I'm not sure you're located in Australia but that's definitely a better price
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4949709
We are not located in Australia, but we ship internationally pretty cheap, shipping can be lowered depending on what you purchase
Well for my build I was just thinking my X8 cables and X6 cables, both for my GPUs, black and white, Should look nice, do you guys showcase builds with your cables?
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4950023
Hi! I've not been sent any showcase builds yet since we are pretty new to the mod world. But if you take a look at GGF Lan party builds, they use mostly our leds and cables. They showcase alot of builds
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4950058
Here: http://search.pccasegear.com/search#w=sleeved
You can pick up extensions for $40. PCCasegear have a better range of products that mwave. I use mwave aswell because its closer to me, pccase is in melbourne but shipping aint too expensive. Extensions will work, just need to find room to hide the long lengths.
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4951931
Are they as good quality? It does look like every cable I need, but just to make sure :D
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4953349
Yeah they are. I contatced them to see if they could mke custom ones for me and they said that cablemod did theirs. Cablemod is a good company, id say they are good quality, but i havnt got them yet. Lots of people use them, even linus and jaystocents.
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4958216
@ClownFace1511 Jay uses custom made PET sleeved cables. The cables are alot thinner than normal cables. Alot of people doesnt like it.
Yeah i saw jays video, then again those cables cost im $450....
Custom Sle​eved PSU S​et - Sanct​um Sleevin​g        $450
Source: https://pcpartpicker.com/user/JayzTwoCents/saved/X79Pxr
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4958643
Can definitly make some extensions with the same quality for alot less. Depending on lenghts.
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4963385
Ive just got my @modguru extensions delivered today and will be putting them into my build this weekend. Its a black & white build so maybe you can check it out. The cables are sweet btw.
Also Martin is a really helpful dude with any question you may have.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4963557
@Nosfy There has been alot of holidays lately which may be the cause of the slow delivery. Cant wait to see the build @Nosfy
I should really have said, I picked it up today. I wasnt home when it was delivered a couple of days ago. They look sweet and I think delivery time was great :)
https://linustechtips.com/topic/365148-modded-cables-or-not/#findComment-4963651
