My ASUS X99-A had been working fine for about a month until today when my computer out of the blue shut down. I turned the PSU switch off then back on and attempted to start up the computer. In order for it to even turn on I need to hold down on the button for 20 seconds. When it eventually turns on I get the Q-Code 00 which means not used. I've tried this over and over along with unplugging and plugging but nothing seems to work. The reset button and the power button on the board itself are completely unresponsive. I've looked at various sites and can't seem to find a solution. Does anyone here know of a fix for this?
https://linustechtips.com/topic/364900-x99-motherboard-problems-help/
RMA the board. Simpls as that, you have a warranty for it, so its best to use it right now. Its probably a motherboard shortcirciut.
But to make sure, check and see if swapping PSU's with another to see if it boots. And just boot with the needed items, no graphics, or add ons.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
