I have the opportunity now to either buy a 290 or a 290x, is there really that big of a difference? I live in Norway and both the 290 and the 290x still sells for about 3100 to 3800kr new (~410-500$). I got an amazing deal with the 290 Tri-X for only 900kr (~120$, used), while I have found a 290x XFX (used) for 1600kr (~210$). I was thinking about using 1500-1600kr (~200$) on the gpu anyways, but the 290 is such a good deal, what do you guys think? Which one would be the smarter choice, save a little money and go for the 290 or go all in for the 290x?
https://linustechtips.com/topic/364813-help-in-deciding-gpu/
Get the 290 tri-x, amazing price, definitely go for it.
https://linustechtips.com/topic/364813-help-in-deciding-gpu/#findComment-4942039
The difference is about 10%. I'd get the r9 290 tri-x, cheaper and most likely with the better cooler.
10-15% difference I think, but not worth almost 100% increase in price
I checked up a little closer now, the 290x is XFX, so I guess it does not have stock cooler
https://linustechtips.com/topic/364813-help-in-deciding-gpu/#findComment-4942061
What do you mean?
In the US the two prices between 290X and 970 are pretty close. So I'm wondering which is better, 290X, 290, or 970?
24 fps for that "cinematic" feel
After a couple weeks of behavioral sciences at my school I can easily conclude my parents need to grow up.
https://linustechtips.com/topic/364813-help-in-deciding-gpu/#findComment-4942150
