i have a old system and its chipset boils water and i need help cooling it
System specs
core i7 920 no Oc
Crappy pegatron MOBO
2 hd 4650 in crossfire
upgraded 550w psu 80+
10 gb of ram
500 gb HDD
any suggestions here is a pic
Cpu: Intel i7-5820k at 4.6 Ghz // Motherboard: Asus X99 Pro // Ram: 32gb of Crucial Balistix at 2400 Mhz // Gpu: GTX 1080 Founders Edtion // SSD: Samsung 850 evo 250gb, Samsung 950 pro 256 gb, // Cooler: Cooler Master ml240r // Case: NZXT h500i
https://linustechtips.com/topic/364332-x58-overheating-problems/
If it's an old system then the CPU cooler is probably clogged with dust.  Friend of mine had the same problem with his old i7-920 stock cooler.
MY CURRENT PC
 CPU: Intel Core i7-4770k COOLER: Noctua NH-D14 MOBO: MSI Z87-GD65 Gaming ATX RAM: G.Skill Ripjaws 16GB DDR3-1600 STORAGE: Samsung 840 EVO 120GB SSD and Seagate Barracuda 1TB 7200RPM HHD GPU: Gigabyte G1 Gaming GTX 970 SLI CASE: Fractal Design R4 PSU: EVGA 1000W 80+ Gold
PERIPHERALS - KEYBOARD: Corsair Vengeance K70 w/ Cherry MX Browns MOUSE: Logitech G500/M100 MONITOR(S): Acer H236HLbid (I want an Asus PB278Q) SPEAKERS: Some Cyber Acoustics $10 speakers PICTURES AND FULL PARTS LIST @ PCPARTPICKER - http://pcpartpicker.com/b/z4Pscf
"Don't get so caught up in trying to make a living that you forget to make a life."
https://linustechtips.com/topic/364332-x58-overheating-problems/#findComment-4935390
Ha, in experiences with non-techies, someone called a tech worker an X58 socket! LOL!!
But cereally, try reapplying thermal compound, it might help.
Otherwise, replace your parts, they're too old. If you don't have the money at least get a better cooler...
Edit: Oh yeah, clean your entire system out, oughta be a LOT of dust in there....
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/364332-x58-overheating-problems/#findComment-4935393
sorry the pic did not load
here is a link scroll down to see image
http://support.hp.com/us-en/document/c01901210
https://linustechtips.com/topic/364332-x58-overheating-problems/#findComment-4935395
its not the cpu cooler i dont have stock cooler
https://linustechtips.com/topic/364332-x58-overheating-problems/#findComment-4935401
no dust perfectly clean and cleaned the system last week
https://linustechtips.com/topic/364332-x58-overheating-problems/#findComment-4935410
i tried removing the  chipset heatsink and it looks like it has thermal pads that are stuck how do i remove it
https://linustechtips.com/topic/364332-x58-overheating-problems/#findComment-4935422
you dont...
When dealing with hardware that old I'd look to replace the thermal pads, if they're stuck it could be that they've dried out which would also answer the temp issue. The important thing to look for when replacing thermal pads is the thickness of the pad itself. Too thick and it will do a worse job of transferring heat, too thin and the heatsink might not make contact at all.
You also want to be careful removing the pad(s) as you could possibly pull off some board components as well, I'd look online for guides.
https://linustechtips.com/topic/364332-x58-overheating-problems/#findComment-4935526
Thank you so it appears that it is thin and dry so how to i remove and replace them
Btw i am not a noob about computers
https://linustechtips.com/topic/364332-x58-overheating-problems/#findComment-4935542
