Fan Control Hardware or Software
Go to solution Solved by Guest,
Depends on the amount of fans, availability of bays, other software (Corsair Link for example) and such. I'd personally prefer hardware control as its faster to change manually, but you can set up curves in software. Saying that, a lot of software is kind of crappy, with the good ones requiring a splitter like NZXT Grid+
I forgot about the software control like graphs, nvm fk hardware software ftw lmao
Should fan control be either under a software control or hardware control? By hardware I mean like physically being able to control the fan speed with a switch system.
I prefer to use speedfan       http://www.almico.com/speedfan.php     It requires a decent amount of setup depending on your motherboard but this should help at least get you started if your interested
I prefer software control because it does not require user input and will maintain low temps while staying quiet when you dont need to cooling power (if you configure your fan curves that way).  I have a fan controller built in to my case and I never use
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
