im about to purchase an msi gtx 970 gpu with ddr5 access, will i be able to connect ddr3 memory even tho its ddr5? heres my build
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($309.99 @ Amazon)
CPU Cooler: Enermax ETS-T40-TB 86.7 CFM CPU Cooler  ($31.99 @ Newegg)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($159.99 @ SuperBiiz)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  ($99.99 @ Newegg)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($332.27 @ Amazon)
Case: Thermaltake VN10001W2N ATX Full Tower Case  ($149.99 @ Newegg)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive: Asus DRW-24B3ST/BLK/G/AS DVD/CD Writer  ($21.98 @ OutletPC)
Total: $1106.20
https://linustechtips.com/topic/363445-msi-gpu-help/
....? not quite sure what your asking the RAM is used by the cpu as a "deskspace" the video card has its own set of ram that is completely separate from the cpu which is much faster than your cpu ram
He probably means GDDR5, instead of DDR5
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/363445-msi-gpu-help/#findComment-4924344
