Hey, it's my first time building a custom water look for my new PC and I wanted to get some opinions on the radiator size I should get.
I will be cooling both my i5-4690k and GTX 970. I want to get some moderate overclocks on it and I had planned for 2x 240 rads. It will be in a NZXT H440. Are two 240 rads good? Too much? Too little?
https://linustechtips.com/topic/362964-custom-water-loop/
I would say a single 360 if you can do it... that way you still have some room left, but it'll fill nicely in the front.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/362964-custom-water-loop/#findComment-4919137
Length over thickness. In my H440 I have a 360x30 in the top and a 240x45 in the front.
<p>CPU: Intel i7 4790k(4.9GHz), Motherboard: ASUS sabertooth Z97 Mark 1 RAM: Corsair Dominator Platinum 16GB (2 x 8GB) GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 (2 way SLI) PSU: EVGA 850w G2 Storage: Intel 730 Series 240GB 2.5" SSD, Western Digital Caviar Black 1TB Case: NZXT H440 Designed by Razer, EK,Alphacool,Bitspower custom loop.
“Peace cannot be kept by force. It can only be achieved by understanding.”
Albert Einstein 14 December 1930
https://linustechtips.com/topic/362964-custom-water-loop/#findComment-4919158
