The NZXT Hue is great, and amazingly easy to conceal.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/362447-best-led-strip/#findComment-4912701
Yeah I saw the Losisticks they seem good only con is that its only 1 set is this bright enough?
probably not, you might want two sets one for top and bottom, can also do 2 colors that way. I went with cold cathode because i like the saturation and one color, so im not sure on who has the brightest. Most are standard 5050 leds,should all be about the same.
https://linustechtips.com/topic/362447-best-led-strip/#findComment-4912745
Do you know where I can another LED strip as you mentioned? Based off the video is another necessary as I feel it will be to bright and I'll have to turn the brightness down.
https://linustechtips.com/topic/362447-best-led-strip/#findComment-4912777
o, i thought you wanted a more even light distribution. These might have a brightness level on the controller, they should be able to turn brightness down by turning down volts. If not that molex gives 12 volts you maybe able to get a resistor to drop it to 7 volts.
https://linustechtips.com/topic/362447-best-led-strip/#findComment-4912793
Yeah you can turn down the brightness on the controller but is it necessary to spend the extra $12?
https://linustechtips.com/topic/362447-best-led-strip/#findComment-4912815
poop, i typed alot and it didn't post, never used any of these so take all that with a grain of salt. Im cheap leds are easy to make, looks like the same company made the ones you linked. I would cheap out. Check Amazon for reviews because if people can mess it up, its the people who post Amazon reviews.
https://linustechtips.com/topic/362447-best-led-strip/#findComment-4912849
