need help!
I had issues with the Intel stock cooler - it was difficult to get it to seat properly and the temps were exactly like you stated.
It sounds like you have a similar issue and the stock cooler's CPU plate isn't in full flush contact with your CPU heat spreader. When you take it off check how the thermal paste has spread, you will probably notice spotty patches.
thats almost exactly what happend. The cooler wasnt properly seated so it almost immediatly fell of when i was taking it off. I looked at the thermal paste and it wasnt spread at all so i cleaned my cpu and the heatsink and tried seating it without the thermal paste. After I got the hang of it I did it with thermal paste and it went like a charm. now my temps are back to normal and the cooler is somehow more silent than it was which was the whole reason I bought a new cooler. thanks anyway and thanks to everyone who replied!
~SV4NL
