Forum Issue!
Go to solution Solved by o0Martin,
The issue has thankfully fixed itself somehow, maybe just needed to clear out the cache, not sure, but that's the only thing I did since it started working again. Thanks for trying to help!
Hey, I tried searching the LTT forums for a solution but couldn't find one, so sorry if there is another post already, but I'm having an issue with the forums which stops me from posting new threads, quoting replies and editing any text.
This is what happens when I try to make a new thread:
http://i.imgur.com/uiPKRxI.png
Instead of what should happen ( http://img.prntscr.com/img?url=http://i.imgur.com/NOJCwRg.png )
Basically the whole text box and editor is gone, same happens when I try to reply to threads too.
It's only an issue on Chrome for me, I'm using waterfox to make this thread.
Does anyone know how I can fix this so I can get back to using Chrome! Thanks in advance :)
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
https://linustechtips.com/topic/362014-forum-issue/
Yeah I use adblock, but I have this page on the exceptions list, so it shouldn't mess with it I don't think
Everything used to work fine on Chrome till yesterday (Forgot to say that in the original post)
https://linustechtips.com/topic/362014-forum-issue/#findComment-4906952
Yeah I use adblock, but I have this page on the exceptions list, so it shouldn't mess with it I don't think Everything used to work fine on Chrome till yesterday (Forgot to say that in the original post)
Even with exception, try to disable all extensions in chrome and check if that helps. It should.
I am sorry for my english.
https://linustechtips.com/topic/362014-forum-issue/#findComment-4906959
Unfortunately that didn't work either :/
I only use adblock and hola, deactivated them both and relaunched chrome fresh but still the same issue
https://linustechtips.com/topic/362014-forum-issue/#findComment-4906980
https://linustechtips.com/topic/362014-forum-issue/#findComment-4911512
