Ethernet question
Solved by MooCow,
That's technically ethernet even though it's a wireless router?
Not exactly.
Read the "What is the difference between a router, a switch and a modem?" section to better understand the difference.
A router technically only needs 2 ports on it (1 to each network). in your case having more it also functions as a switch.
Hell, you could read the other sections to answer questions you might not have thought of.
Does that help?
