yea, fill them up kinda like halfway with normal tap water, give them a good ol' shake, and when you drain them after the shaking, a fair amount of gunk should come out
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/359828-radiator-cleaning/#findComment-4879523
Just tap water? Should I follow it up with distilled?
Once your done cleaning it with tap water rinse it with distilled. I personally hook it up to the tap and run warm water through it for 10 mins to flush it out.
https://linustechtips.com/topic/359828-radiator-cleaning/#findComment-4879541
