It says in Notes what they include. With LAN the other is only driver (smaller file) and another includes the management software. Its up to you. With chipset there is two versions. Either one will be all right. The newer might fix some errors in device manager.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/358920-drivers-help/#findComment-4876528
