How far away is it ? Do you have any metallic structures or thick walls in-between ?
If you already have working Wi-Fi devices, you can get a cheapo Asus dongle for under $20. They get the job done and they're pretty darn reliable.
Also, don't get that Apple Airport. First, it's an access point and you need a network adapter (if I understood you right). They're fancy and all, but the price is far high for the performance.
https://linustechtips.com/topic/35827-wireless-network-adapter/#findComment-459471
Guest
