Bit coin mineing?
Go to solution Solved by Oshino Shinobu,
It is by no means a way to get free money. You'll spend more on electricity than you'll make in Bitcoin, and it will take ages to break even on the hardware, even if you do manage to be making a profit.
Bitcoin mining was a big thing a while ago, but now it's pretty much pointless.
https://linustechtips.com/topic/357210-bit-coin-mineing/#findComment-4847583
What is this!!! I herd about it from a friend and from what I understand it is a wY to get free money. Please let me know any info you have about it. Thx
It's not worth it any more.
https://linustechtips.com/topic/357210-bit-coin-mineing/#findComment-4847588
what the other ppl said not worth it anymore since the exchange rate went to so low numbers that you can hardly break the hardware cost and the electricity cost when bitcoin was a big thing you could easily do it but now when the hardware became so big in bitcoin mining that you cant do it whit gpu anymore its not worth it
https://linustechtips.com/topic/357210-bit-coin-mineing/#findComment-4847637
