overclocking help
Go to solution Solved by TheSLSAMG,
It depends on the cooler, but I wouldn't go over 1.325V given your cooler would be able to handle it under 85C.
I have a 4790k im messing with the overclock  i have a asus z97 ar MB. when i run 5 way optimization it wants to overclock all cores the same. to 5.1 with a 1.401v
i can manually put it lower.
question is what would be the ideal voltage?  i feel that 1.4v is to high
i dont need the fastest overclock just a nice balance would be awesome.
https://linustechtips.com/topic/356790-overclocking-help/
https://linustechtips.com/topic/356790-overclocking-help/#findComment-4842403
Although this is not your board it is similar. Read here: http://techreport.com/review/26789/core-i7-4790k-devil-canyon-overclocking-revisited/2
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
https://linustechtips.com/topic/356790-overclocking-help/#findComment-4842486
1.4 is way too high.  5.1 is probably a dream OC.  Don't go over 1.3 if you can.
i set is to 1.285v and 4.8 ghz runs the test great no problems i think i could go higher but i really dont know what im doing. i wish i had one of you guy here to check out this overclock my other friend tells me i lucked out in the processor lottery. im pretty sure if i knew what i was doing it would hit 5.0..
any way thank you for the advice and help very much appreciated
https://linustechtips.com/topic/356790-overclocking-help/#findComment-4844741
