Yesterday my frontpanel audio stopped working. It was after I went to a friends place so I thought it might have been a loose cable. I tried replugging the audio cables in my motherboard and it still doesn't work. My computer can still detect that I plug in a headset, but no sound is produced. My headset works perfectly fine using the jackstick on the back of my pc. The reason I need to use my frontpanel is because it can detect the impedance of my headset and adjust accordingly.
Any suggestion what to do?
specs:
win7/64bit
i5-4690k
Asus Maximus VII Hero
Define R4 Fractal Design
16GB 1833 MHz Hyperx
500GB 840 Evo
1TB Western Digital Blakc
Zotac Amp Extreme Gtx 980
Corsair RM750W
BIOS-version/dato American Megatrends Inc. 0707, 16-05-2014
I'm using the program Realtek HD Audio Configuration (the one that comes with the motherboard)
https://linustechtips.com/topic/356665-front-panel-audio-not-working/
you can rerout the cable from the front to the jack port on the back for a quick and dirty fix, if you have a too short cale for that i reccommend a driver update
Thanks, but I rather fix this properly. I've tried to update my driver, but every time I run the setup this comes: http://imgur.com/Bh1M2iy
I've tried to wait a few minutes, but nothing is happening, I've run it as administrator as well. I downloaded the driver from Asus webpage.
Check the audio settings in the bios make sure they haven't switched between HDaudio and FP audio, double check the driver software too and check what output mode its using.
Finally check the windows playback devices make sure the headset is listed there, enabled, and that windows says its outputting sound there.
I've checked my bios settings and it was set to HD audio as usual. The driver software is set to HD audio as well. I'm not entirely sure what you mean by output mode, but its set to output into my headphones and not digital or something like that. The headphone is listed under the windows playback devices and windows registers a sound output.
Are you sure the Hd Audio header on your mobo is fine? I would check for bent wires, etc.
System Specs
Windows 10 Home x64 AMD A10-7850k APU ASUS Strix R7 370 Overclock Edition 2GB | Corsair CX500M ASrock FM2A88M-HD+ G.Skill Ares 2x4GB
Accessories
Corsair K70 RGB | Razer Deathadder 2013 Razer Kraken PRO
Checking if it was set to digital is what I meant.
You said the front panel adjusts based on the impedance of your headset, are you able to see the changes, if this is done automatically then this could be where the failure is?
You can adjust it yourself and no sound is produced no matter what impedance I choose
Is there anyway to check under the panel, where the jack is, and check for a wire that may have become unsoldered? Just a thought.
It's always a good day if you woke up breathing.
