So I started playing GTA V, and i have some weird texture loading bugs
http://imgur.com/a/PtFOS
this usually appears when driving fast
i have the latest gpu drivers and also GTA V patch released by Nvidia
How to fix them?
Specs:
Intel core i3 4160
MSI GTX 970
8GB 1866 Kingston Fury
https://linustechtips.com/topic/355980-gta-v-problem/
That's simply the textures taking time to load. It's like what happens on consoles - it renders shit at range, in low resolution and only increases it when you're close. But it's taking a while to load for you.
Running on a mechanical drive mate?
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/355980-gta-v-problem/#findComment-4832520
i have both ssd and hdd, but I intend on playing it long after i'll finish it, so i have it on HDD, because my ssd is kinda small.
will ssd fix this?
https://linustechtips.com/topic/355980-gta-v-problem/#findComment-4832546
will ssd fix this?
Possibly, i've not tested the game yet but based upon the fact that all previous GTA's have done that with textures, it's down to hard drive speed, and the cpu. Your i3 may also be struggling a little, since it's only 2 cores - but putting it on an SSD will also help.
https://linustechtips.com/topic/355980-gta-v-problem/#findComment-4832579
thanks
https://linustechtips.com/topic/355980-gta-v-problem/#findComment-4832592
