Hi guys,
I have a PC which was built for home use.But now I want to buy a graphics card to play upcoming games like witcher 3.
Pc Specs:
CPU: i5 3450
MoBo: Intel DH61BF
Ram: corsair 4gb
monitor : AOC E970Swnl
PSU : cooler master RS 400 (bad one)
HDD : Toshiba 1tb
Case : cooler master elite 311( with a fan on back)
I'm planning to buy gtx 960.
-Will it be okay?
-Any bottlenecks?
-CPU cooler necessary?
-Should I replace PSU?
-Extra fans necessary?
give me some suggestions.
https://linustechtips.com/topic/355917-need-help-with-pc-components/
Bottlenecks shouldn't be an issue.
You should probably get a better psu and an extra fan for side intake.
Getting some more ram could also be helpful.
It would help to tell us where you're shopping/located and your budget.
Moving thread to New Builds and Planning--please post in the correct subforum in the future.
If you're still running your stock CPU fan. I suggest picking up the CM 212 Evo. It's really really good value.
That's fine if the OP doesn't mind the noise. It's not like the cpu is unlocked for oc'ing.
