I bought some Hardware for my x99 build.
Two asus strix 980's
Asus x99 s motherboard
16gb Corsair lpx ddr4
Corsair rm 750 psu
Corsair h110i GT cooler
I7 5820k cpu
Samsung 850 evo 250gb SSD
Seagate 2tb hdd
I cant decide which case I should get.
I realy want the h440 because its the best looking case for clean builds in my opinion.
But I read about the airflow being so bad that the system is going to have high temps/overheat
Is that true ?
https://linustechtips.com/topic/355541-case-for-x99-build/
As long as you put some nice fans in the case the H440 would serve you well
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4827234
enthoo pro
r5
h440
s340
define s
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4827242
Well, the air that's being exhausted from the GPUs will be stuck and won't push to the bottom exhaust grille/fans since there is that PSU cover.
You could put fans in the top, but since your GPUs will be blowing down the case and not up this wouldn't create a nice flow, it might make it worse possibly.
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4827256
Corsair rm 750 psu
I7 5820k cpu
Seagate 2tb hdd
Is that true ?
I have both a X99 Deluxe and a H440 case. Also running two non references cards in SLI. Temps are totally fine. Cards run at 65 under full load and CPU is like 45 or there about.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4840612
Please tell me the exact fan setup you used and which fans :)
I have three 120mm Corsair SP fans at the front. One 140mm Corsair AF as back exhaust and on my H100i I have two 120mm Corsair SP fans.
They are all quiet editions.
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4840818
Where can i find pictures of your rig ?
Cables will be re-done.
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4840850
Nice *-*
I want to put my PC on to my desk only 1m frome where Im sittig...so how loud is it ?
This is how I have mine. To be honest I don't hear anything because I use a headset.
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4840928
And if u dont use one ?
I want to have a nearly dead silent pc
Then I would say its reasonable. Its definitely not silent tho.
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4841025
Ok thx.
Then i have to go with the enthoo luxe and some good silent fans
You can definitely get quieter fans than the ones I got. The Noctua range are highly rated. They are ugly tho.
https://linustechtips.com/topic/355541-case-for-x99-build/#findComment-4841092
