So basically.
My specs in in my Sig and profile
I've just got my graphics card today and put it into my computer.
Now here comes the annoying part.
My computer boots.... but no display appears.
All of my fans are working, the motherboard LEDs are working, the grahics card fans are working, but no display.
I've cleared CMOS.
I've tried to boot with 4 single different RAM sticks.
I've used a different graphics card.
I've removed my SSD.
Nothing....
However... when the computer boots, my monitor goes from sleep mode, to displaying 'No Signal'
So im guessing there's a signal being passed through, but not the right one.... if you understand.
I've used HDMI to DVI cable and a displayport. Neither works, same result.
Can anybody help? Literally been waiting for about 8 months for this to be finished and now it doesnt work makes me want to cry and really really really pissed off. Oh and i have to do coursework.
                                                      Professional Graphics Designer | Case: NZXT Phantom Orange and Black | Motherboard: MSI SLI PLUS X99S
        CPU: Intel i7 5820K | Graphics Card: Zotac nVidia 1080 AMP!
                                   RAM: Corsair Vengeance 16GB DDR4 2400Mhz | Storage: Samsung 850 PRO 256GB, Western Digital Black 3TB & Western Digital Red 3TB |
                                                        Monitors: Acer Predator XB271HU 27", Acer Predator XB270HAbprz 27" and BenQ GL240 24" | PSU: Corsair AX860i |
https://linustechtips.com/topic/354267-initial-boot-no-response-help/
So basically.
I've cleared CMOS.
Nothing....
Can anybody help? Literally been waiting for about 8 months for this to be finished and now it doesnt work makes me want to cry and really really really pissed off. Oh and i have to do coursework.  FUN
are you sure that you connected the cables right? reseat tthe connectors at the psu and gpu see if that helps, try another pair of psu cables if you can
I've just tried that, same result. Boots but no display.
did the boot without the gpu?
It boots whatever i do to it. It just doesn't boot into windows no matter what. The graphics card removed i still have to force close it... it doesnt shut down by it own accord when the power button is pressed. So i have no idea what to do.
does it boot to the bios with gpu in there?
No bios or anything shows up on the screen. With or without RAM, GPU, HDD, anything. Im guessing it goes through it though because the fans are at 100% for about 5 seconds then they calm down to the built in case fan controller speed. Which is at the top of the case.
it's a evga card so thats supposed to happen so, im sorry to say but its a dead card, if you can check the card with another pc that would be great, to check if the mobo's pci slots  are ok.
on that idea put the card on the other slots of the mobo see if that help's
Slot 1 and 3 has been tested by two seperate cards. A 480 and a 970. Neither card showed a display so i'm guessing it's not the card.
exactly it's the mobo's pci slot i think, wait does it post without the gpu?
Nothing loads with anything. With the GPU in the fans speed up when the power button is pressed then goes back down to the set fan controller speed. No display. Same thing happens with it out. All the MB LEDs are also on. I've tried booting multiple times without certain components, checked all the wires and i can't figure out what's causing it not to boot. Off to go try the card in another PC so i'll update once i've done that.
check the cpu get's hot without the heatsink if it does it the mobo pins that one is bent or broken if it doesn't its the cpu that is dead
Turns out it's the CPU pins that are actually bent. Must have happened when i inserted the CPU to begin with. Oh well. RMA time.
msi has great rma, sorry that this happened,to be honest the same thing happened to me after inserting a usb thumb drive and shaking the case and boom bent pin
I just bought another from Amazon and RMA'd it through the company i bought it from. Nothing else i could do, plus i need my computer done yesterday.
