Need help fixing up code (JavaScript)
Go to solution Solved by Hazy125,
As far as I can see, that code works exactly when I tested it. Only problems are the lack of spaces around the name on the alert. So my guess is JavaScript is currently disabled on your browser. Usually this isn't the case, but you might have accidentally checked a box in Chrome or you're using Internet Explorer which has an annoying habit of randomly blocking JavaScript when it feels like it
<body> <script type="text/JavaScript">var name = prompt("What is your name?",0); alert("Hi"+ name + "Hope you are enjoying JavaScript");</script> </body>
For some reason the prompts are not coming up
By the way I am a beginner programmer and don't know a lot about JavaScript
The long haired pure bred dachshund called Davis
https://linustechtips.com/topic/354008-need-help-fixing-up-code-javascript/
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
